Mixer Tap won't turn off
18 Oct 2011
Somerset
Got a strange problem with a mixer tap.
The hot tap was stuck open and wouldn't close, I took out the tap barrel and it had seized completely. Replaced it with a new barrel and this worked ok, until I put the metal tap handle back on and then it will open but won't close again. I then have to drain the system, remove the barrel and re-install it, to stop the flow.
Anybody got any idea of anything else I can try?
If the spline length on the new tap insert isn't exactly the same length as the original one, then replacing the tap top could cause it to bind.
John :)
