Monoblock kitchen mixer taps wobble
24 Aug 2009
London
Hi
I've just replaced my kitchen old monoblock mixer taps with a new one. The taps are fitted to a stainless steel sink. I've noticed that the new taps "wobble" when used. The nut underneath the tap is as tight as I can get it but the tap still wobbles. I am using flexible hoses. Could this be the problem? The old taps used copper tails and didn't move at all. Is there anyway to brace the taps or should I replace the flexible hoses with the copper tails?
Any help is much appreciated.
Thank in advance.
Flexible connectors aren't helping you, and unfotunately the gauge of steel used for modern mainstream sinks is quite thin. If you are capable of changing to copper tails then do so. If you take one of the flexible tails to a plumbers merchant they may be able to sort you out :)
WIth posher taps you get a stiffening plate to go with unposh sinks, between the tap's E shaped fixing doobrie and the underside of the sink.
Try a really good plumber's merchant which sells lots of taps, they may have them for sale.
Pipes aren't there to hold taps still, they often undo and leak where that's the case.
You're right, chrisr, but having firmer pipework does assist in stopping tap wobble. And as long as the OP isn't swinging from the tap, then using copper right up to the tap won't increase the chance of any leaks. :)
Have occasionally wondered if there was some way of manufacturing a bracket that could be fixed onto the taps' fixing screw and braced onto the cupboard or even some sort of self adhesive plate on the back of the sink.
