Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi you are not happy with the tap tails that come with a monoblock kitchen mixer tap, say it comes with copper tails but you would prefer flexis. Can you get these or are they all specific to the tap?
either or, your monobloc should have either 10mm or 12mm inlets, the ends that connect into the monobloc itself, 8mm are rarer but you never know. Unless it's an obscure Chinese make that has been supplied with a weird size.
Take the copper tails with you and match the diameter of the end that fits into the tap with the flexi.
Only thing I would add to that is that if they are 8/10mm inlets on 15mm flexis then the internal bore would be pretty similar at the tail end as the copper so little difference in comparison IME.
