Hi guys, from reading the forums seems like lots of people having C/H problems this Xmas - here's mine:
During summer had a number of problems with the boiler had it serviced, 3 port valve and pump changed and everything seemed fine. However problems have started to resurface, the main one is that the boiler will not get up to operating temperature when just the central heating is on. Boiler thermostat will get to around 58 degrees then it will switch off the burners. With water on, either on it's own, or at the same time as CH, boiler will operate correctly. The HW circuit is much shorter than the central heating circuit so obviously a lot less resistance but still don't really understand why it's doing what it's doing, all radiators start to warm up but they are not getting hot enough!!
Boiler is also refusing to ignite on random occasions but not sure if that's related to this fault!
Thanks for reading any suggestions will be much appreciated.
