Hi guys, first post.
I've read a couple of threads on here about TRV's but they were quite old so i wondered what peoples prefs were nowadays.
I'm after some decent chrome TRV's for a house renovation. They will be feeding Stelrad compact range of rads.
I've been looking at Danfoss RAS-D² Chrome TRV 8/10/15mm Angled & L/S but heard they may be a bit cheap feeling? and also the Drayton TRV4 Chrome TRV 15mm Angled.
However on the Drayton the below review has put me off somewhat.
"Valves bodies are blank off apart from a small hole. As both ends take the same body the flow rate is restricted so if the radiators in question are not given priority the flow is practically non existent. Drayton's previous TRV which I've had 12 for approx 15 years have a 15mm opening in the lockshield and the TRV valve itself had only the valve with no added restriction of a small 6 mm hole (approx) drilled in the body opening".
Any thoughts or recommendations?
