mortar with anti crumbling additive
26 Jul 2007
hi, sorry another question :)
I need to mix up a stiff 5/1 sand cement mortar to fix a shower tray.
I assume this means a fairly dry mix, i.e. not too runny?
Also, what should I use for the anti crumbling additive?
Personally, I tend to make it quite a wet mix with a bit of plasticiser (or washing up liquid solution if you like) in it. Lay it rippled (as for bricklaying), and tap gently flat with a rubber mallet if necessary, and leave overnight to set hard. Alternatively, use floor tile adhesive - same effect.
Never tried it to be honest. Worth priming the floor (ply you say elsewhere) with it anyway
