1. I'm afraid I don't know how to take the covers of the m.vs. so all I can tell you is that the arm which is supposed to whizz over and go rigid when the zone stat is turned off no longer does so.
Can you
hear the valve motor working when you turn the stat up and down? If you can then either the actuator is faulty or the complete valve.
Here are Siemens instructions for removing the motor and housing:
1. Before working on the synchronous motor housing replacement you must switch off the electrical supply.
2. Lift up fully the two coloured locking sliders.
3. Press in simultaneously on both plastic tongues and lift up the plastic cover.
4. Disconnect the electrical internal connector.
5. Now remake the electrical internal connector from the new motor housing unit.
6. Hold the coloured sliders up and locate the plastic tongues in their respective slots, push down firmly until the tongues are fully located then push down the coloured locking sliders.
7. Turn on electrical supply and test for operation
The pump doesn't have any numbered settings - just a knob with a pointer to a band which goes from thin to thick with a circule at one point which I presume is the half way mark. We have it pointing to about 2/8th inch from the starting point. If we turn it up higher we get a whooshing noise in the rads nearest the boiler. The boiler has no numbered settings either; we usually set it to about three quarters of the way from the start.
Does your pump look like this?
If so the fixed speeds are the one, two and three dashes on the red body of the pump.
None of the rads have air in them but one or two don't feel as hot at the bottom as at the top, particularly one in the sitting room where there is quite a difference between the flow and return pipes, even with the lockshield fully open, so may have sludge in them, unless it is that the underflow pipe sizes are not correct or the pump not high enough.
Certainly sounds like sludge. If this is the only radiator exhibiting this problem, it would be worthwhile removing the radiator and flushing it through with the garden hose. this is how you do it:
1.
Turn off the heating
1. Close down the lockshield completely
2. If you have a Drayton TRV, remove the head (see later), put on the decorators cap (This is a blue or white cap rather like a very large bottle top) and do it up tight. I do not have any experience of Danfoss TRVs, so I don't know if its possible to shut them off completely.
3. Make sure you have plenty of dust sheets, towels etc under the rad connections.
The muck which comes out will stain your carpets badly.
4. Put a container (I use an old meat dish) under one of the joints to catch the water. then loosen the connection between the valve and the rad to let the water out. This is a slow job and you will have to empty the container regularly. Do up the connection while you do this. You can control the flow by how much the connection is undone and by opening the bleed valve slightly.
5. When no more water comes out of one end of the rad, undo that connection completely so the rad is free to move.
6. Repeat 4 at the other rad connection, but lift up the free end of the rad to make the water flow to the other end.
7. Repeat 5 at the other end.
8. Do up the bleed valve, carefully lift the rad from the brackets and
turn upside down. This prevents any water coming out when you carry it outside to flush through.
9. Flush the rad from both ends until you get no more much out.
10. Replace the rad (reverse of removing, but there is no water to drain)
Radiators are very heavy and I would not expect you to do this on your own
Since we have some sludge in the expansion tank (despite the fact that an inhibitor (Sentinel) was supposed to have been added when the new boiler was installed about 5 yrs ago (how long is it supposed to last?)as well as these other problems, we thought we had better have a power flush.
The fact that you have had hydrogen formation means that the inhibitor is too weak. Don't forget that, every time you bleed a radiator, you are letting out water with inhibitor and replacing it with plain water from the tank. If you have had a valve leaking and been bleeding a lot you might not have much inhibitor left!
If you do decide to have a power flush, get several written quotes and check what sort of guarantees they give.
However, I note your comments that this would no deal with limescale in the heat exchanger. Is there no chemical that will do so or is the heat exchanger irreparably damaged now?
I had a Kingfisher at my last house and it started kettling. Luckily this boiler has a large cast iron heat-exchanger, unlike modern ones which are usually aluminium or stainless steel. I added Sentinel X200 Noise Reducer to the system and the noise went away.
Details are
Here
I can't see any facility for locking the m.vs. in the manual position (Siemens ZA - V228C) or for setting the pump to a fixed speed, the lack of which certainly makes balancing difficult, esp. without an electronic balancing device, which our installer didn't use. The difference between flow and return seems to vary.
Not familiar with the Siemens valve, so I don't know how to lock the valve open. The instruction on the Siemens web-site just says:
When draining/venting your system put the Manual lever in the ‘MAN’ open position.
If we have an auto-bypass installed, as you suggest, will this make any difference to the flow to the towel rail?
It shouldn't, but it might be worth including the towel rail in the balancing so it does not take more than its fair share of the water. As it is the first rad after the pump, the lockshield will be almost closed. The other valve can also be closed down the same amount as the flow is dictated by whichever valve is closed the most.
We have a mixture of old (1974) Danfoss and newer Drayton trvs. I know how to get the heads off the former and free the pins if they get stuck but not the Drayton ones
Set TRV4 to MAX then turn the large knurled nut under the white plastic top, see pic below.
Please excuse my ignorance. I am a 72 yr old female with an even older and more infirm husband who is not knowledgeable about these matters so I am groping in the dark and trying to inform myself so we can get a proper job done.
You certainly don't give the impression of being an ignorant 72 year old female.
[/url]
