Motorized Valves
22 Apr 2008
Kent
I am replacing copper cylinder (indirect) but am not sure wether to stick to the two single motorized valves system which is allready there and working or replace it with a new three way port system, or does it not matter which way you have it? HELP!!!
why spend money on a y-plan when you have, i assume, a perfectly good s-plan?
there will be no noticeable difference and ill bet you wont enjoy the y-plan wiring much.
The current system has a better flow rate, more redundancy.
So I vote with Nickso. A 3 port would be a downgrade, especially if the boiler is over 80,000 BTu.
Thanks for the information guys, i will be sticking with the present system on the back of what you have suggested. Once again thankyou!!!!
:D
