Fully pumped central heating system with 3 port danfoss valve. When hot water only selected radiators coming on also. ab, b and a pipework ports are hot. Motor recently replaced. The lever does not seem to go all the way to the hot water position on the valve. Would it benefit the system replacing the valve body and keeping the same motor. can there be a fault with the valve body itself.
