hi i just painted all interior walls and now about 2 months after i have noticed little black spots pf mould forming in corners what do you guys/gals recomend for this to remove mould and stop it coming back?
This is of interest to me too. We have a modern house (less than 15 years old) and the interior walls are painted with magnolia emulsion. Over the last few months, I've noticed very faint stains - a sort of yellowish discolouration in a few areas - usually top corners where two walls and the ceiling meet. This only seems to happen on the inside of external walls. Is this mould? As far as I'm aware, the house is quite dry. We have a hygrometer in it and it seems to read in the region of 35-40% humidity most of the time. It's double-glazed and pretty well insulated. Obviously it's winter and we don't have the windows open much.
If it is mould, what's the best way to treat it? I wouldn't mind re-drecorating anyway as the paint is original and a bit grubby in places (generally at "child height)! Should I just wipe with some bleach before re-painting?
I borrowed a moisture meter from a friend who works with wood. Obviously, it's not calibrated for plasterboard, but I stuck it in several walls and the readings it gave were generally the same in the ?damp? areas as in the non-damp areas round the rest of the house.
