One of my truly delightful children climbed onto a radiator to reach a light switch and the radiator brackets came away from the wall taking large chunks of plaster with them. The radiator is now leaning away from the wall at a precarious angle and needs to be secured.
The wall is lathe and plaster over timber studs and, frankly, not up to mounting a radiator on. I am reluctant to simply repair the plaster and re-mount the radiator as the same thing could happen again.
What are my options?
I thought of floor mounting the radiator, or cutting out some plaster between the studs and screwing in a bit of wood horizontally on which to mount the brackets. Or I could cut out a section of the plaster behind the radiator and put in a bit of plasterboard secured to the studs instead.
What about a new floor mounted radiator? However, these tend to be low level and even more tempting to stand on.
All helpful suggestions gratefully received.
