I'd really appreciate any advice anyone can spare for me. I've read up a lot but not sure if I've actually got the final picture in my head.
We moved into a new house, well new to us. It has a Potterton Suprima 70l boiler and a Megaflo CL170. There is a programmer on the boiler and a thermostat upstairs. There is also a immersion switch.
We've come from a small flat that just had a combi boiler which was simple, when we wanted hot water it was produced etc.
What I don't understand is how this system works - that may sounds stupid but a couple of times we have run out of hot water and I wasn't sure why (apart from the fact there was no hot water left..)
My understanding is the boiler comes on at certain times and heats the water which is then stored in the megaflo, but when the megaflo is empty (that shouldn't happen too easily but has) then what happens? Can hot water not come via the boiler into the megaflo and straight out? Or if the water ran out and then the immersion in the megaflo was turned on, how quickly would the water heat?
I know the megaflo stores water and pumps it out at high pressure.
What is the best setup for this, I've not changed the programming since we moved in a figure it could do with a tweak. If the boiler was left with HW on constant what happens when the megaflo is full of hot water? Does it stop or does it continue and hot water is just wasted and pumped out of the system.
I'm not sure if I'm being clear or not so please ask questions, as I said I'd just like a bit of advice as to the best way to have this working.
Thanks and as I said any help appreciated.
