Moving a Radiator
3 Sep 2008
Tyne and Wear
hi there, i have a radiator (first on my system) with the 'fast drain' valve on it. it sits in front of a window in the room that will becvome my kitchen and the window is going to be taken out and replaced with french doors. To save money i told the builder i would move the radiator ready for him to do his job on the window.
I figured this will be my method and i am hoping someone can step in and let me know if i have got it right or if i am missing somthing/doing something wrong!
1. turn of water at entry to house (under kitchen sink) - i presume this feeds the heating system - or is it just taps?
2. attach a hose to the drain valve and open it with a spanner (turning anti-clockwise)
3. allow system to drain and remove radiator
4. go underneath the floor (there is a crawl space) and modify piping with push fit plastic stuff
5. drill holes in floorboards at the new location
6. re-use the copper legs to show above floor level
7. re attach the radiator
8. refill the system
i have heard about adding an additive to the system - where/how does this get added (and indeed what is it!!!)
i hope i haven't bitten off more than i can chew and any help would be appreciated.
thanks again
Eddy
What type of system do you have? what boiler?
If it's a sealed system then -
  1. Turn off both valves on every rad except the one you are moving - TRV's without a 0 on them may need decorators caps.
  2. Drain down the pipework and rad
  3. follow your steps from number 4
Before you fill the system, fill the rad you moved with a 1L of inhibitor, then open every rad, fill the system and bleed and then run till they're all hot and for 15mins after that to disperse the inhibitor.
If it's not a sealed system then it's a bit more complicated.
Thanks Madrab.
How do I know if it a sealed system? I presume it is... I have a combi boiler.
If I choose not to put a radiator back on straight away cap I just cap the 2 pipes underneath the floor?
Do I add the inhibitor into the pipes prior to capping them?
Thanks again for forth coming advice...
Eddy
