We have a half integral garage and want to convert the integral part into a utility/cloakroom so it properly becomes part of the house. The meter and fuse box are currently together at the back of the garage so I assume one basic requirement is that the meter is moved to the front. The fuse box will also be replaced during the works but we don't want to change the position.
Before going off with grand plans and quotes I should like to go through a few assumptions in case it upsets any ideas.
~ Is it allowed to have a CU (boxed in) in a utility room with water, roughly 2m horizontal separation?
~ We want to cut a doorway under the current fuse box so that the new CU sits between the top of the door and ceiling. A 30cm gap is theoretically sufficient. Is this allowed/possible?
~ When the meter is moved, who is responsible for reconnecting the meter and fuse box/CU?
~ The separation between meter and CU will be the length of the existing garage. Would the CU and meter be directly connected or would space be needed for an intermediate fuse board or connection point?
~ As part of the final works, new circuits will be added. Would it be acceptable to move the meter, keep the existing fuse box and upgrade to CU later? Or would a CU be required immediately, for adding circuits later? I ask because it is not a completely straightforward switchover and it might be more practical to do all circuit additions/changes together.
Any other things I might need to consider?
