Unless you have a very big house, consider whether there are that many lights because the person who put them in decided to use lights that are not very good at doing the job of lighting up rooms.I have 50 odd that will need doing
I think you mean that they are 12v. That makes them ELV. 230v is defined as LV.Luckily when these were put in I went for LV spots
REALLY??? You are misinformed. Tell me how a 50watts halogen at 12v consumes less than a 50watts halogen at 230volts., they aren't on the endangered list at the moment and don't consume anything like mains halogens
Indeed... you can see how it soon ads up ...
about 20 in the kitchen.
Chances are you will need to change the dimmers.
The chances are also non-zero that when you find an LED bulb and dimmer combination which works OK, it will stop working, or will work differently so that each bulb is not at the same level of brightness, when you replace a bulb in the future. Be prepared for the possibility that you'll have to replace all of them in a room if one fails.
Two things that might need some thought is how to earth the new system as LV didn't use the earth
O dear. Did you not read TWs post when he said:
"I think you mean that they are 12v. That makes them ELV. 230v is defined as LV."
