multi fuel stove existing ceramic flue or flue liner help
8 Jun 2011
I have a chimney on external wall of my lounge. The chimney sits external to the house so there is no breast in the room.
It had a gas fire in previously and has an 8" clay/ceramic liner in the chimney going straight up.
I'm building a fake chimney breast out of block in the lounge to house a multi fuel 8kw Stovax stove.
Due to measurements and restrictions its going to be tricky to put a flue liner down and have soot access.
I was going to put a 904/316 flue liner down and then a T piece with cap on the bottom going to the stove rear flue exit. Problem is the stove sits further than 6" away from the T horizontally.
Options are:
45 out of stove rear flue, stove pipe to 45 T piece with cap onto 6" flue liner inside the ceramic liner. Soot door on the rear of chimney giving access to T piece Cap for soot collection.
Or
45 out of stove rear flue, stove pipe and break into the existing flue ceramic flue. Then fill the void below leaving a drop gap in the chimney for soot collection and have a soot door at the rear of the chimney outside.
Its easier/cheaper to go with the latter, but does anyone see any issues?
Why dont you fit a sump adaptor and sweep through the stove?
I'm not sure what a sump adaptor is. I'm happy to sweep through the stove though, but wanted more to hear advice on whether an external chimney with a ceramic liner would be ok for the flue of the stove, or if people had seen problems and advised putting a steel liner down.
Cheers
As this comes up so often, I’ve put together this generic post; read the links but not all may apply to you.
You can DIY but you need to understand the Building Regs (which changed in October), submit a Building Notice & pay a fee. Your LABC will inspect &, assuming everything is OK, issue a compliance certificate; the BI may want to witness smoke & spillage tests. No compliance certificate may lead to difficulties when you come to sell your property; if cannot produce a compliance certificate in the event of a problem, your insurance company may invalidate your policy & reject any claim.
Lots of archive threads on this, & other things you have to watch out for, here a few links for you to read:
http://www.stovesonline.co.uk/stove_building_regulations.html
http://www.hetas.co.uk/public/certificates.html
http://www.solidfuel.co.uk/pdfs/buidling_regs_consumer leaflet.pdf
http://www.diynot.com/forums/viewtopic.php?t=183614
http://www.diynot.com/forums/viewtopic.php?t=211524
http://www.diynot.com/forums/viewtopic.php?t=242738
http://www.diynot.com/forums/viewtopic.php?t=224751
& some more sobering just in case you think it’s all a load of old tosh:
http://www.solidfuel.co.uk/main_pages/news.htm
http://www.dailymail.co.uk/news/art...wood-burning-stove-leaks-carbon-monoxide.html
http://www.eveningnews24.co.uk/news/warning_over_heaters_after_norfolk_couple_s_death_1_811099
Also get at least 3 quotes from local independent HETAS installers:
http://www.hetas.co.uk/nearest_member
You might be pleasantly surprised & you should ask yourself if you really want all the hassle & risk getting it wrong; climbing onto the roof with an 8M stainless steel snake on your back is not for the feint hearted!
__________________
Read more: http://www.diynot.com/forums/viewtopic.php?t=267604&highlight=#ixzz1I6jlicut
Thanks for that i'll have a good read through.
I've had a couple of HETAS people around and due to my arrangement its not a clear "do it this way". I've even seen the HETAS installation guide and they dont have an example for my setup.
The guy recommended doing what i suggested in going stove->45->pipe->Into clay liner
and then build up underneath leaving a void for soot collection with a soot door in rear of chimney outside.
Problem is i need to tell my builder what to do with the chimney before i get a stove fitter in.
So really i just wanted to know if i should go down the liner route or flueing into external chimney ceramic liner is sufficient.
Thanks indeed
If you have a clay pot lined chimney then you dont need a liner, fit a sump adaptor to that and then your vitreous to that
The problem with using an 8” open fire clay liner with a log burner or multi-fuel stove is it’s rather too large to maintain all important flue temperature through to the pot. Most HETAS installers (& I’m not one) will recommend either a 5 inch or 6 inch max twin wall SS liner, insulated full height with loose Vermiculite; but don’t take my word, check it out. :wink:
Incidentally, my own personal stove is an 8Kw Stovax Riva inset; coming up for its 3rd year, a great stove & cheap to run. :lol:
Thanks again guys.
So It may be best to go for the liner in the end as you say the 8" clay may not draw correctly?
I can't go sump on the bottom of the clay liner as my stove flue will be slightly above the bottom of the clay liner. I guess i could smash a bit off, but would be unsure of seals then.
Only thing i heard about the twin liners is they need replacing every 10 years. We're looking at this house to stay longer than that.
If i go liner it may make the chimney build a bit easier.
I'd go Stove->45 bend->flue pipe->45 T piece with Cap->6" Liner 904/316SS up chimney->suspending cowl.
hmm decisions
