Look at the bt whole home mesh wifi system. One disc plugs into your virgin hub, and you locate the others at strategic positions around the home to give you full coverage. It allows you to have guest access too. We’ve had it for 3 years and had tried power line adaptors, range extenders and extra hubs. The bit mesh system just works.I have Virgin fibre. Can I add an extre wifi hub to improve coverage within the house, and give the passord to guests while restricting access to the other? If so, what do i connect it to?
Yes . Same at each end.same plug each end
When I did mine, I bought a reel of loose cable. You can make a neater job if you cut it to length and fit your own ends. It’s really easy - the complete kit with crimping tools and even a line connection tester is really easy to use and can be bought for less than 20 quid. I used Cat 5E in my house. You need to get proper copper cable though, not copper clad aluminium (CCA) cable.Well, I ordered the recommended WiFi round Access Point and injector for a start.
I am looking at ready-made RJ45 cables. Is "Cat 5E" the right cable spec to use?
House is over 10m tall so I may end up with some long runs if I add a switch for more wired connections.
What's a good socket to use?
When I did mine, I bought a reel of loose cable. You can make a neater job if you cut it to length and fit your own ends. It’s really easy - the complete kit with crimping tools and ebven a line connection tester is really easy to use and can be bought for less than 20 quid. I used Cat 5E in my house. You need to get proper copper cable though, not copper coated steel cable.
Only for the patch cables, not the main fixed runs...and the stranded, rather than solid cored.
You've left the switch out in your examples. So when you get to your switch with 8 cables plugged into it, what will those cables be - flexible or stranded?The crimp on plug ends don't work reliably, with the solid cores. The solid cores are fine as you suggest, for fixed runs, socket to socket.
So it would be...
plug - flexible - plug - socket ------------ solid -------------- socket - plug - flexible - plug
If you wanted to not bother with sockets at all, then it would be...
plug ------flexible -------plug
