MVHR fills the flat with sewer stench
21 Jul 2024
Hello DIY-ers, my MVHR pumps the most foul air into every room of my apartment, usually just after I've poured water down the kitchen sink. There is a condensation drain on the MVHR, which runs down to plastic inline attachment, and I think this is a check valve. See photo.
My diagnosis: either the valve is stuck open, allowing drain smell to back up into the MVHR, or the check valve requires some water like an S-bend, and there is not enough condensation in the MVHR to keep the value wet.
If water is required for the valve, I could pour some into the MVHR.
If the valve is stuck open, it will have to be replaced, and I need to get it off. Unfortunatly, I can't get it off because the pipework is rigidly attached to the walls with Talon hinged pipe clips.
Is there a tool for removing a Talon hinged pipe clip? Or shall I Dremel them off?
You are more likely to get help if you post in the appropriate section. The Moderators can move this for you. Click on 'Report' to ask for that.
