My boiler
20 Dec 2006
Berkshire
I have got a Potterton boiler and recently changed the programmer. I can get the heating to work by manually changing the motorised valve but I noticed that the room stat does not work. Can someone help please?
Check and then double check your new programmer wiring and then check it again :shock:
your room stat does not work?
Explain why and we can help.
David
How do I check my wiring ? The only way I can get my heating working is to disconnect the motorised valve head and manually switch over. I think the room stat is working now.
Your room stat does work?
From where I'm standing the position appears to be:
You changed your programmer and now something doesn't work.
Without knowing any more the answer appears to be that you have connected something wrong.
I don't know what, or how.
There might be someone else who can diagnose it without being able to see it, but I certainly couldn't. I think I may not be alone.
I am unable to diagnose the problem with the unseen wiring either.
Thats an odd room stat, one day it works but another day it does not. It must be a seven day programable stat?
This bandwagon is stationary Gents, so there's little point in you jumping on it. :roll:
