It appears that the house we've moved into has no wall ties! Although we're not sure, we think the house was built in the 1930's. Both internal and external walls are brick, but having just had insulation pumped into the cavity I asked the chap doing it to check if there were any wall ties, and it appears there aren't!
The building has suffered a bit of movement in the past, but seems fairly stable now. I've had two SE's look at the existing 'cracks' and they've both suggested fitting helixical ties, which I'll do. But I'm wondering if having no wall ties between the inner and outer walls is normal?! I wouldn't have thought it was a good idea!!
So, I'd like to retrospectively fit some wall ties of some kind, to at least give the place some kind of strength. Does anyone know of any mechanisms for retrospectively fitting wall ties? Preferably without disturbing the inner wall rendering? I'm not sure if anything like this exists, but if it does I'd like to look into it.
David.
David.
