Just wanting to know how similar the wiring config. is gonna be as im replacing an apollo with a Baxi solo15? And would rather have 2day go easy rather than pulling hair situation.
Many Thanks
How are you using it with or without roomstat(fully trv`d)
Apollo has permanent live and switched live and will have the pump wired back to the boiler
if using the solo with a room stat then do away with the permanent live and use what was the switched live and put it into the L connection of the solo along with the live for the pump.
If not using a room stat and fully trving it connect pump live to terminal P/F instead of in with boiler L
