I have a relatively new Worcester Bosch Combi system (3 years old). Worked perfectly until three weeks ago. But now none of the radiators get hot and some stay completely cold. I called in Worcester Bosch engineer. He says that it isnt a boiler problem. He is probably right because the outflow pipe from the boiler gets very hot but the return pipe remains cool. After a while the boiler turns itself off because the outpipe is so hot and the pump is working. The Worcester Bosch engineer diagnosed a blockage in the pipes and went away.
Since then have had two plumbers trying to sort it out. The first diagnosed sludge even though a power flush was done three years ago when the new combi system was installed. He wanted to do a new powerflush. However that was going to cost me £485 with no guarantee that it would fix the problem. I didnt go for that. May be I should have.
The second plumber has just spent a whole day failing to solve the problem. He drained the whole system and had water running through it from the filler on the boiler through the system and out of a drain fitted to the return. He claims that there is therefore no blockage. Also the water is now clear. He has also tried getting air out of the system.
I am thinking it must be air because some rad heat up a bit some of the time and others at other times. None of them get hot though.
I am running out of options and ideas
