A strange object has been found fitted at the back of a boiler feeding a fully pumped 27 year old vented heat only system. Water dripping from this device is a hazard as it can enter boiler electronics.
View media item 31327
But what is it and can it just be removed and replaced with a blanking plug?
It is fitted on an unused flow connection, where a blanking plug is expected. It is not part of a circuit and does not feed another component or pipe. There is a ring of holes which weep water even when the system is cold. The end cap can be screwed down against a spring onto an adjustable stop ring.
If it is an AAV (or ultra low cost pressure relief valve) its location at the back of a boiler where drips can enter electronics seems bizarre. Was that OK even in the 80s?
Any help appreciated.
