Can anyone please help solve this mystery?
I have a ferroli combiboiler which started dropping pressure pretty rapidly.
A plumber changed the AAV which had no effect and we have ruled out the pressure relief valve and the expansion vessel is fine.
We were told it must be a leak on the system so had a specialist company with thermal imaging out as all pipes are under concrete floors. He identified two possible spots and both were dug up.
The builder claims both spots were dry and so filled them in with cement again after covering the pipes in plastic. He advised we get the other firm back to do a gas test to trace the leak exactly. Since then pressure has stopped falling.
Could there be another explanation or is it likely that the leak was on the pipe the builder exposed and he has somehow plugged it when the filled in the hole with cement?
Is there any other possible cause on the boiler?
We
We
