Nabis monobloc mixer
11 Sep 2007
Hi guys,
Fitted the above mixer, lever type, new pipework etc in bathroom.
Used a isolation valve on the 15mm, before the flexi's supplied with the mixer.
All works fine, except that when drawing off water the tap makes a sort of 'whoosing' noise!
The noise is worse with the lever in the center and lifted half way up, when lifted for full flow it is better, but still not right, It also does it when half lifted to hot and cold side.
Thought it might be high pressure causing a problem, but have turned down the isolation valve to reduce flow, this is a little better, but again not right!!!
Any advice on what could be causing this?
I also fittted the same Nabis deck filler on the bath, 2 tap hole, with no problems.
Look forward to your valued advice.
