Hi Guys.
Need your help with this boiler. Been Ok for past couple of months since we moved in - until now.
Boiler fires up ok but then 30 secs or so later it locks out. This happens on hot water or heating. THe heating pipes stay cold. I have also noticed that the demand light for hot water is always on even when the hot taps are off (have checked)
I've taken the front cover off to have a look. Seems to be overheating. THe pump and the rectangular metal box that heats the water was red hot. When it cooled down i checked the pump and it is working and spinning. I've also had a look at the diverters (though i'm no expert). When i took the switch off the hot water diverter the light (green)went off on the panel. Then 'pin' on this one moves out but not back in. I can push it back in easy enough. The pin on the heating on is out and will not move at all.
After this 'faffing' i did get hot water for a while so tried for heating. THe heating pipe on the left side got red hot, i could hear the boiler overhreating and it locked out. Its as if the water is stuck and has no-where to go.
What on earth has happened here. Is this an easy fix or do i have to raid the kids piggy banks for a new pcb.
Chris
Chris
