National Grooming Gangs Inquiry Announced
Since 2021 there have been more robust recordings of ethnicity. Not perfect I agree. White or non white - not easy to confuse. Pakistani percentage maybe less, I'm not sure.
from the same report you keep pasting:
It is important to highlight that some data fields used in the analysis were not consistently recorded – for example, barely a third (35%) of child sexual abuse offences had a record of the victim–perpetrator relationship, and ethnicity data on suspects was also largely missing. That's without even getting into the argument that "child sexual abuse offences" is a massively wide set of offences, most of which have noting to do with organised gangs raping kids.
There isn't a statistic in any records anywhere in this great land that would make this statement remotely true...
Its ok to admit you are wrong.
Hmm, 85% plus, year on year. :unsure:
"...It is not white British males committing the majority of rape abuse against kids, via rape gangs. There are plenty of official reports confirming this and I have posted them for the forum idiots to appraise themselves of...."
Liar.
You say
Basically you falsely post up dodgy dossiers / stastics
Transam is not interested in any of your links
You and that other fruitcake Denso cannot be trusted with documentation
The pair of you cherry pick posts and alter them so how can you two fruit cakes be trusted
Yes exactly
You cant :giggle:
It's a question, do you think all people should get similar punishment, with no favour either way?
Yes, they should when found guilty but it counts for fùck all if they are not pursued or prosecuted because of their ethnicity. There is no disputing that some gangs were simply not pursued solely because of their Asian ethnicity.
You seem to be getting your knickers in a twist over nothing. The statistics refer to individuals and not gangs, in any case.
This is undeniable fact...
A number of high-profile cases - including the offending in Rotherham investigated by Professor Alexis Jay,3 the Rochdale group convicted as a result of Operation Span, and convictions in Telford – have mainly involved men of Pakistani ethnicity. Beyond specific high-profile cases, the academic literature highlights significant limitations to what can be said about links between ethnicity and this form of offending. Research has found that group-based CSE offenders are most commonly White.
Read more
Research on offender ethnicity is limited, and tends to rely on poor quality data. It is therefore difficult to draw conclusions about differences in ethnicity of offenders, but it is likely that no one community or culture is uniquely predisposed to offending. • A number of studies have indicated an over-representation of Asian and Black offenders in group-based CSE. Most of the same studies show that the majority of offenders are White.
Read more
I wonder if biking from the boatyard understands what this says......
Most grooming gang offences carried out by white men, police chiefs say​
or this....
The vast majority of grooming gang offences are carried out by white men, the National Police Chiefs’ Council (NPCC) has said.
or this....
New figures from the police database show that, where ethnicity data was available, 85% of “group-based” child abusers were white in the first three quarters of 2024.
Richard Fewkes, NPCC
The same data for the whole of 2023 showed 83% of offenders were white.
Read more
Across various contexts (online, intra-familial, group-based, offences by under-18s) a large majority (between 76% and 91%) of suspects were White
read more
Pointless debating with you. You've slipped back into repeating the same post over and over and over which is a sign that you have your fingers in your ears, your eyes covered and just sit there going la la la la la la…
Do you think that sex offenders and grooming gangs should be treated the same, that is, no favouritism?
I'm not sure what you are trying to show or prove? Everything that you moaned about previously has been covered and the public made aware, in previous enquiries. No doubt the new enquiry will go over a lot of old ground and will say things like victims of abuse were ignored and that social services were afraid to stick their neck out for fear of appearing racist.
Do you think that no Pakistani grooming gangs have been punished or summat? What is your actual gripe?
I'm not sure that's true, it was definitely a factor but I don't remember that ever being the only factor.
Remember that the police often didn't treat them as offenses at all. The victims were classed as consenting participants.
Dunno what u are on about
Standard. Take your 'ed out of your arris and do a little reading boyo. You should get past that recently rejuvenated Elon Musk inspired racism of yours. Fair play, Baroness Loise Casey did warn that it would thaw out a lot of racists/Muslim haters like yourself.
If you bothered to read ANY factual portions of previous enquiries, you would see that what you are saying is largely untrue.
Yep. Nothing to see here. Move along…..
