Need a Tumble Dryer front felt seal this size
1 Jun 2004
Sorry to go back to this, but as I cannot get the answer from dealers, I need a front felt seal for a Hotpoint TDC32P - it measures 12mm wide and is to cover a drum circumference 121cm.
either a direct replacement or a suitable suggestion as to adaptation?
C00307120 complete kit. eBay about 10 /15.00.
Many thanks again rocks, for your time and the reply. I will contact them to get the size.
The front duct cones with a seal on it. But is now obserlete. You can try 2 seals one the vtd range. Coo142613 , 14 MM. Or coo276750 16 MM. That will pos be cheaper than the kit.
The first part number I gave you is only 2 MM extra on the side. But 5 ft long so use that and cut some off.
Having taken rocks1's advice, I have been able to fix this machine, adapting the suggested felt seal, and making new brackets for the support for the drum.
Thank you again rocks1 for your helpful advice, as usual.
