Need advice painting: how do I do the edges? +Do I need cauk
OM2
18 Jan 2007
I'm painting a room in our house
I've done the large parts with a roller and have left the edges
A few problems!
1. I have used a brush for the edges - urrrgh! You can see the brush strokes
I think the brush I have is old (but I thought usable)
Should I invest in a better soft brush?
And do I need to stroke up and down only or something??
2. Do I need caulk?
I read somewhere (I think it was WikiHow), they said that I should put a thin line of caulk down edges??
Do I need to do this? What's the purpose of this?
3. AND do I HAVE to do a double coat? :(
I think I have the answer to that one already - a lot of places look patchy - and overall the walls looks just not right!
I was hoping I would be able to just get away with it!!
Any advice would be great
OM
The secret of a good finish is what's called "maintaining a wet edge". Brush the ceiling/skirting line first (called "cutting in") but only do a short distance (I just do a foot or 18inches) , then while the brushed paint is still wet, use the roller to get as near to the ceiling/skirting as you dare. Once you've started, work continuously across one wall so your roller is always connecting up with wet paint. Only stop between walls. If you want to see how easy the professionals make it look try this: http://www.dulux.co.uk/video/da_painting_walls.jsp
What's the purpose of caulk?
Caulk is a flexible filler, useful where you've got movement that causes a crack to reappear time and again. It can't be sanded so be careful to apply only as much as you need, then smooth it with a finger
Do I HAVE to do a double coat?- a lot of places look patchy
You've answered the question yourself !
thank u thank u!
brilliant reply - something that helps immensely
i have to do a double coat, so all is not lost - i'll do as u say (and as said in the video)
