I have had different advice from different suppliers and seed different methods on here.
Im installing a solid oak floor for a customer.
The room is roughly 8.6m long x 3.6m wide.
They want the flooring to run the length of the room from window to french doors.
The original floorboards also run the length of the room and they want the new flooring to go the same way.
From various suppliers ive been told to:
"secret screw" the boards using a 6mm thick foam underlay and go with the floorboards.
"secret screw or nail" at 90 degrees to floorboards with a dpm installed under it.
"install as floating floor"
"install 6mm wbp ply over floorboard first"
I want a proper answer on how to install this.
Do i ply the floor?
Can i actually go with the floorboards?
Do i need a dpm?
Do i nail it with a floor nailer, secret screw it, or glue it?
How much of an expansion gap is actually needed?
Im putting new skirting over it however MDF skirting is only 18mm thick.
thanks
Do i ply the floor?
Do i need a dpm?
thanks
