Need help with ?100 year old radiators
18 Feb 2015
Ontario
Hello DIYnot.com:
I have some heating questions.
I have attached 3 initial pictures that I hope will help.
The radiators may be 100 years old. Is that possible to tell from looking at them?
1)Can anyone tell me the difference between radiators A,B, and C (pics attached) or know where I can find out?
2) A and C while different from one another can both be turned off. As far as I know B cannot unless that ?six sided ?bolt can be used to do so? Do you know what that bolt is for? Can the radiator be turned off by it?
Thank you kindly for any expertise,
Mary
To show picture you have to post them into the post
find the line Show My Images Upload New Images below the text box
Click on Show, then on the images to be posted
View media item 91073View media item 91072View media item 91074
I doubt they are 100 year old as that age tended to be built in sections.
The 6 sided bolt is NOT a valve. It is the nut that secures the pipe to the radiator. If you loosen that nut the pipe will not be held water tight to the radiator. Water will leak if you loosen it ( or if un-lucky water will pour out of the joint )
