need help with new thermostatic shower install
21 Oct 2007
i am just about to start installing a new thermostatic mixer shower in my bathroom. i have a combi boiler and no water tank.
the water pressure is not that great. however i have use a mixer shower off my bathroom taps and its seems to work ok.
would this be the case with a thermostatic mixer?
i am going to fit a shower tray in the corner of my bathroom dose it matter where i put the drain hole in the tray?
ant new tips are great full.
The shower should be fine.
does the tray not have a hole in it already?
thanks guys, the shower try dose have a hole in it.
i have been told i may have to raise it off the floor the beams go across and i may not be able to cut them? they are 6" x 2"
i also want to move the radiator will i have to drain all the system and re fill up again to do this?
you don't have to, but on a combi just as easy to.
is there a way to temp plug the pipes if i cut them off?
yes if i can, or just until i move the rad to the other wall?
