Hi all
My CH/HW Worcester combi has an SFL (Selkirk) IL flue system fitted thus:
Boiler -> vertical flue connector -> 450mm of vertical 125mm flue pipe -> 120 degree bend -> connecting flue pipe into liner installed in existing chimney.
The first vertical SFL IL pipe's outer insulating wall has corroded through in one small section (2" dia) so I need to replace the section of pipe.
My question is how do I remove the flue pipe?
I know it's a push & twist type fit so I thought I could just untwist it but it won't budge. Even with a boa constrictor it won't move and all I've succeeded in doing is squashing another bit of the insulating wall!
Does anyone know the best way to go about this?
Pete
Pete
