It actually needs moving back to back against the wall it is currently against. So pipes through the wall. The flue which goes through the wll now will not when moved and I need to add several pieces to take it up further (the installer in 2009 made it so fumes gather round the garden and don't blow away upwards–a fail IMO in installing).
1. The boiler has just been serviced so should not need adjustments just moving couple of feet. Can't find anyone to do it so it's a DIY job.
2. The boiler is a Grant 15-26 2009 vintage. Condensing I think with a flue that has air inlet at bottom and insulated SS flue. Can I replace this with a black finished flue?
Any other advice appreciated. Thanks.
