Need to remove cistern from wall but ....
31 Oct 2010
I am trying to remove a toilet cistern from the wall as the siphon is not working and I need to replace it (and some other parts).
It's a close coupled system.
Unfortunately the two screws securing it to the wall are badly corroded and I can't get any purchase on them. There's not really enough room to get at them with a drill.
What's the best way to release these screw?
Photo below:
TIA
Cut a slot in the head with - ideally a dremel - or a hacksaw blade. Butcher them off with a 4 inch grinder :wink: Having first butchered the syphon to get it out the way
Thanks for the advice.
Hacksawed a groove in the top of the screws and eventually got them out! :D
Replace with stainless or brass screws and washers - Stainless shouldn't corrode so much - and brass is soft enough to tear apart using 'alternative means' if you can't get a screwdriver on them next time.
best of all I think are stainless Coach Screws. They are just screws with a hex head you can turn with a spanner. M4 x 40mm should do the job nicely. If you just need a few ebay is a good source.
to reduce the rsk of cracking the china cistern, have a wide stainless steel washer (a "penny washer") under the head of the screw, bearing on a thick rubber washer such as a bath tap washer against the china.
Damn, the last 41 years I have been smashing the cistern with a lump hammer to remove the screws.........
