I'm having some work done on the front of my house that requires the bell box to be removed and replaced.
Is there a way to disable it temporarily? Currently it's triggering the tamper every so often when the builders are banging away next to it, and they need to remove it completely tomorrow then put it back again.
And I assume they are easy enough to remove? Unscrew the bell box cover, undo all the wires, remove. And refit is the removal in reverse
The alarm panel is a DA Abacus
