Neff ceramic hob T1281N1 ring fault
6 Jul 2012
Cumbria
I have a Neff T1281N1 ceramic hob which has developed a fault on the zone with a double element, the inner part works fine but when you switch on the outer section it stays on for a bit and then keeps turning on and off as if its getting to a thermostatic cuttout temp, but it does it frequently and even at the highest setting. The inner section stays on, and all the other zones work fine. Is there a temp sensor on this or is it the main pcb? :(
