What's the difference? I think posative means pressured inlet and negative means no pressure inlet, is that right. May help if I told you the issue.
Need to run two electric showers but don't want them running off the main due to the old problem of another outlet in the house gets turned on and effects pressure. So in my old house used a Salamander ESP80 below the tank (about a meter below) and that could run both showers all day long.
New prop planning a similar sytem, but is the ESP80 the best option, or should I use Techflow or Stuart Turner options?
Any pointers would be appreciated.
