Hi there,
I have recently purchased a Nest thermostat and am trying to connect the Heat Link to my boiler (Glow Worm Easicom 28). I have so far successfully completed everything as per the guidelines and even followed some further instructions on the Nest Forum website for my specific boiler. (see below).
At this point I’d like to point out the boiler did not have a thermostat attached previously.
The boiler will generate hot water but will not fire up the heat for the radiators. When the nest thermostat is turned up I can hear and audible click from the Heat Link so I know they are setup and working together.
My main thinking at the moment is the in built clock on my thermostat is the reason things aren't working, as when I switch on the heat at this point (how the heating normally worked) the heating comes on (even is Nest is ‘calling for heat’ or not. So basically this is over riding anything that the nest is requesting and doing it’s own thing.
I have 3 cables running from the boiler front right panel.
1) L ---> L in heatlink
2) N ---> N in heatlink
3) RT ---> T3 in Heatlink
Plus
L ---> T2
Hope this helps,
Any help would be greatly appreciated.
Dan
Plus
L ---> T2
Hope this helps,
Dan
