im about to be fitting a new bathroom but as its quite old, theres no service valves on any of the pipework. Is there an easy way to do this without having to shut off the water to the house? If I do this, will it affect my central heating at all?
Usually 15mmm sink and loo and 22mm for any bath.You can get flexi with built in iso valve.Thanks Ill give it a try. As Im going to be putting in service valves am I right in saying that I need flexi connectors that are 15mm to 1/2” for the taps?
Guarenteed to leakUsually 15mmm sink and loo and 22mm for any bath.You can get flexi with built in iso valve.
They are available as push fit or compression fitting.If i bought flexi with built in valve, what would I need to fit on the pipe end for it? Just a nut c/w olive? Or maybe push fit?
Thanks. Would teeing off the bath taps not be better as the cold is fed from the mains water supply? Every tap in the house has decent pressure, its only the shower thats low
