Hi
I am building an extension. It is extending from our existing rear wall of a 1929 bungalow and will be just under 6m wide by 10m long. The new walls to be built are approx. 23 linear metres with 3m of existing wall (currently a kitchen that sits out 3m into the rear garden).
One 6m end will simply be the existing rear wall of the bungalow.
The problem is, that with just over 52 m2 of new floor space, we're struggling to work out what type of floor to lay.
Something that size being made as a large reinforced raft slab will likely need expansion gaps, but would spread its load out along the whole of the existing ground area (obviously on top of MOT, sand and insulation).
We were instead thinking of choosing block and beam which would be resting on the inner skin of the new walls (5.1m clear span) for the most part but how do we attach the 3m of beams (with clear span of 5.1m) into the existing kitchen wall? The bricks in that wall are white, and as a wall they seem fine but individually they can be broken quite easily. Also, to make matters worse the wall is resting on victorian style stepped foundations made of the same bricks.
To add an extra bit of information, when the trenches were dug and concrete poured no provision was made for any sleeper walls in the middle of the space and it would be very difficult to get a digger back there to put them in.
I'm hoping a full size snooker table will eventually sit in this room. I expect that makes the loadings at the end of the beams greater as well.
What are your thoughts.
