Hi all,
Looking for some good advice on boilers.
I've recently moved into a 4 bed semi with a bathroom and shower room. 14 rads. When we purchased the survey flagged the loft tanks as needing work. Anyway, the current boiler (potterton prima f) is very unreliable and about 20odd years old so I'm looking at replacing. I'm also having boiler relocated about 5 feet from shower room and into garage.
Direct change to another regular boiler (wb24i) is coming in at £2300 fitted. Not keen on this idea as the tanks are also in need of updating plus currently runs a whole house pump which is very noisy.
Option 2 is a wb38cdi combi. This is coming in at £3200 fitted.
Option 3 is unvented megaflow cylinder with wb24i system boiler. Coming in at £4500 all fitted.
My current flow is 17lpm then with two taps open 12lpm. Don't know pressure.
I've had two opinions from plumbers. 1st is that our flow is ok for combi and it will handle all our needs. 2nd guy said we should update mains from current 1/2" to 25mm poly to increase flow. I spoke to Thames water and they instantly told me on phone that 25mm would give me .83l per second 1bar. I understand that boiler input however is 15mm, so does that mean that the flow would be restricted back to current flow rate when the pipe downsizes for the boiler fitment or does some magic happen here??
What's the opinion on current flow rate adequate/inadequate for combi/unvented?
