1/2 inch pipe coming off of the 1 inch pipe up to the rad the 1/2 inch pipe coming off the other end of the rad down to the 1 inch pipe, he put a 1 inch shut off between the 2 1/2 inch pipes to force the water through the rads.
Better chance if the rads are piped TBOE (Top, Bottom, Opposite Ends) but still no guarantee it will work properly with a modern boiler and pump. Is it a system boiler? Or a combi? Not sure what you have over there. Are the pipes steel/iron? With a shut off valve between the rad tails, then shutting off one rad will shut them all off as flow will be required through each rad... Even if only partially closed it is very restrictive.
Where is the pump? A sketch of the system would be helpful
Can't find that model so can't tell if it's heat-only, system or combi. Is it 55000 BTU/h, natural gas?
I'm sure Canadian heating and plumbing systems have differences from UK practice and this is a UK based forum. You might get better advice if you can find a similar Canadian - or US - based forum
