    Dismiss Notice
New Boiler
Discussion in 'Plumbing and Central Heating' started by mentalhibby, 19 Feb 2021.
  1. mentalhibby
    mentalhibby
    19 Feb 2021
    Thanks Received:
    Country:
    Hello all. We have just had our old boiler changed to a new shiny Worcester Bosch. Open vented system. First day following installation the following occurred: rumbling and banging in pipes and hot water spluttering out expansion pipe in header tank. Obviously tank overflowed and exited all over our patio.
    Called engineers and they sent out someone to turn down new pump to position 2. However the following morning the same problem. Boiler starts up, rumble and clanging in pipes and hot water shoots into header tank. Heating continues as normal for about 5 minutes then same thing happens, banging, clanging and into the header tank.
    It also happens during the day if we turn up the room thermostat by two or three degrees. Has to be more than pump overrun surely?
    Engineers booked to return on Monday and I'd appreciate any ideas beforehand. Hot water tank seems fine and no discolouration of water from hot taps.
  2. ianmcd
    ianmcd
    15 Aug 2010
    23,521
    Thanks Received:
    9,718
    Lanarkshire
    Country:
    post pics of your pump and motorised valves and new boiler
    • Like Like x 1
  3. Sponsored Links
  4. Quilts76
    Quilts76
    19 Feb 2021
    24
    Thanks Received:
    2
    Country:
    Deffo like the above has said, I would be interested to see the configuration on the cold feed and vent.
  5. Did they powerflush the system?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
