OK, where to start... I'm in a new build and to cut a long story short want to add some extra sockets in the garage for a small workshop - the only high power item I occasionally use is a 2kw heater, everything else is relatively low power - battery chargers, drills etc.
While I'm at it though, I have 'concerns' about the electrics in this place. It's all signed off of course so ticks all the Part P boxes. Anyway, I'll not open that can of worms . But to give you an idea...
Shortly after moving in I noticed one of the smoke alarms hanging off the ceiling - it was 'secured' to a standard metal backbox using plasterboard screws. I put the proper screws in but noticed sparks coming out of the smoke alarm - significant arcing from the cheapo choc block connector they used to wire the thing up - the screws were all threaded and the wires were basically just resting on each other. I fixed this.
I've also noticed many walls where cables are running outside safe zones - i.e. cables running down the middle of a stud wall where there are no fittings on the wall at all. I'm sure that's not allowed but hey, it's signed off Part P so must be fine.
Also, the circuit arrangement just seems bizarre in my book. It's a 3 storey town house with a detached garage:-
RCD 1 (63A):-
Smoke Alarm - 6A
Floor 1 Lights - 6A
Lights (?) - 6A
Water Heater - 16A
Ground Floor Sockets - 32A (spur to garage)
RCD2 (80A):-
Central Heating - 6A
Floor 2 Lights - 6A
Ground Floor Lights - 6A
Floor 1 & 2 Sockets - 32A
Cooker - 40A
So 4 lighting circuits but no separate circuit for the garage? (the CU is full btw)
The garage is fed from a (non-fused) spur from a kitchen socket - so it goes:-
Kitchen Socket -> DP Switch in Kitchen -> DP Switch in Garage -> Garage Socket and Fused Spur to lights (the socket isn't off the fused spur). So technically the garage socket is a spur off the kitchen socket that then has a spur to the lights. Oh, and the armoured cable runs through a 1.5" plastic pipe roughly 2" below the soil surface in the garden, over to the garage.
SO, sorry for rambling. My questions are:-
1. Adding sockets in the garage. There's no easy way to add a dedicated circuit from the CU. What would you suggest for adding more sockets in the garage? Install a mini CU with 16A RCBO and then just keep radial for the sockets? I'm happy to do a ring but seems pointless? I'll probably keep the fused spur for the lights off the 16A circuit. I also plan to use one of these for the sockets: http://www.screwfix.com/p/mk-20a-dp-secret-key-switch-metal-clad/29973
2. Does the general state of the electrics in this house seem unusual / worrying? I mean, it's all signed off and Part P so must be fine, right?!
Thanks in advance!
Andy
RCD 1 (63A):-
Smoke Alarm - 6A
Floor 1 Lights - 6A
Lights (?) - 6A
Water Heater - 16A
RCD2 (80A):-
Floor 2 Lights - 6A
Cooker - 40A
Thanks in advance!
Andy
