Hi all,
We're currently having a new combi boiler installed as part of a biggish extension build, to replace an existing gravity system.
The boiler we're intending to put in is a Wooster Bosch Greenstar 440 CDi (http://www.worcester-bosch.co.uk/homeowner/products/gas-boilers/greenstar-highflow-440cdi).
The plumber has already carried out his first-fix around the new extension with pipework leading up to the existing bathroom. All of the DHW pipework is 15mm copper pipe, and for some reason I was expecting to see a 22mm 'mainline' of pipework branching to 15mm to feed every tap/bath/shower etc. The boiler is not in place yet, but I can only reckon that he's going to connect the 15mm stepped up to 22mm to the boiler.
Is this correct, or should it be 22mm branching to 15mm? The WB product information states that the DHW should be 22mm to the 'first branch' then 15mm from there onwards, and the DHW outlet on the boiler is 22mm. If the nominal setup is to use 15mm pipe, why does the boiler provide a 22mm outlet?
Am confused as hell and can't find anything concrete to suggest what the picture should be. Can anyone enlighten me, please?
Cheers,
Gary.
[/i]
Cheers,
Gary.
[/i]
