    Dismiss Notice
New Fitted Wardrobes - External Wall - Mould
Discussion in 'Wood / Woodwork / Carpentry' started by Georgie73, 9 Dec 2015.
  1. Georgie73
    Georgie73
    8 Dec 2010
    378
    Thanks Received:
    5
    Country:
    Hi
    We had a carpenter make us some wardrobes across an external wall which has a chimney breast on it. Carpenter completely sealed the opening of the fireplace before fitting the doors. There are no air bricks in the walls. Today I have noticed some fury mould type stuff on some suede shoes which are on the base of the wardrobes. All the hanging clothes are fine.
    Has this happened because the fireplace has been sealed off? The suede shoes were leaning against the side of the chimney breast.
    What should we do to prevent this happening again?
    Many thanks.
    George
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    15,139
    Thanks Received:
    1,638
    Kent
    Country:
    Chimney breast requires ventilation to prevent damp, also good idea to have venting to wardrobe.
  4. Diyisfun
    Diyisfun
    15 Jun 2004
    7,174
    Thanks Received:
    275
    Norwich
    Country:
  5. Georgie73
    Georgie73
    8 Dec 2010
    378
    Thanks Received:
    5
    Country:
    Thank you. Yes, it's definitely a cold wall. I will do as you suggest.
    Many thanks
  6. foxhole
    foxhole
    14 Mar 2006
    15,139
    Thanks Received:
    1,638
    Kent
    Country:
  7. Sponsored Links
  8. Georgie73
    Georgie73
    8 Dec 2010
    378
    Thanks Received:
    5
    Country:
    I have to try something - any other ideas?
  9. Diyisfun
    Diyisfun
    15 Jun 2004
    7,174
    Thanks Received:
    275
    Norwich
    Country:
    I bet it improves it.
    I think I used wallpaper paste to stick it, was a very quick clean job.
  10. Burnerman
    Burnerman
    7 Feb 2008
    20,382
    Thanks Received:
    3,966
    Northumberland
    Country:
    I did the same...it was a pink slab stuff from wickes. Dramatically effective, and easily stuck with a blob or two of silicone.
    John :)
  11. Georgie73
    Georgie73
    8 Dec 2010
    378
    Thanks Received:
    5
    Country:
    I'm going to give it a try. Thanks guys.
  12. ree
    ree
    6 Feb 2014
    3,193
    Thanks Received:
    408
    California
    Country:
    OP, you have nothing to lose by trying the polystyrene route. But if the wardrobe is built-in how do you intend to cover all the rear wall, and any return walls with continuous sheets of poly?
    Ventilation behind the unit(s) is a must - high and low.
    Does the room have an air brick vent?
    What type of walls do you have - solid or (insulated?) cavity, do you have render?
    You would help yourself by opening up the chimney flue for sweeping, and then ventilating top and bottom. Why? Because the c/breast might be the next surface to give you trouble - due to an unswept & unventilated flue.
    In my limited experience, bedroom built-ins are often a source of trouble.
    • Like Like x 1
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
