Hello, I recently bought a house that has an attached barn. The area in the picture was historically used for storing hay, and we also want to use this area for storing hay. Around 500 20kg bales = 10,000kg.
Green line: Top of an internal wall
Blue lines: Top of an internal wall
Purple lines: Beams with ends on top of the walls
Red lines: Very thick circular beams with one end on the wall and one end inside the outer wall
All the flooring is very weak, perhaps damaged by damp or wood worm. The previous owners had doubled up the flooring in some places.
What is the best way to approach replacing the flooring?
Can we simply remove all the existing flooring and lay new wooden planks?
Should we consult a structural engineer to determine if the area can still be used to support a heavy load?
