new heating installation
31 May 2008
Yorkshire
Hi all
I'm wanting some advice if possible on a new heating installation in my property.
i have 2 wood burning stoves 1 in the lounge and 1 in the dining room which in winter we use quite often. Now if we have the heating on at the same time to heat the upstairs rooms and the fires its so hot it can melt your face. I have a combi at the moment but i have old cast iron rads that i want to keep but i dont want to fit trv's because they dont look right with the rads so below is what i would like to do so please advise me if this is a good idea or not.
I want to have installed a baxi combi this is a natural gas version, but want to independently control the kitchen, upstairs and downstairs temp settings independantly so thought about adding three 2 port valves to control the kitchen plinth heater upstairs rads and downstairs rads. Then fit a programmer with 3 wireless stats.
let me know what you think
thanks again everyone
Well you could but its an odd solution to a simple problem that you dont like the look of TRvs.
Why not paint TRVs to match the colour of your radiators?
Tony
the problem i have is that i have repoduction brass valves with the plastic wheels on all my rads that i have installed and at £70 a set its a shame to have to replace these with modern trv's
You can get TRVs with a remote sensor phial.
With a little fiddling you could mount these under the floor and put the phial descretely in the room nearby! But you would not be able to adjust them easily unless you left a small flap or something but once set then that should not need to be touched.
Tony
cheers for that info tony
do you know any websites i can look at to see pics of this.?
in regards to my original question do you think its still possible to control the kitchen,upstairs and downstairs independantley via wireless thermostats and would you say that three 2 port valves is the way to go.
thanks again
Its possible to so that but a very expensive and over complicated solution!
Tony
but say i didn't want to go down the trv route could you advise me on a more simple way of achiving what i originaly asked.
thanks again for the info
Just turn the lockshields down a lot on the downstairs rads?
Or is that too simple?
Tony
