Ok, firstly I have a vented gravity fed indirect hot water system with cold tank in the loft.
I am fed up of running out of hot water in the mornings so am looking to change the cylinder, but not sure what i need.
At the moment I have worked out that with 65c hot water, 15c cold water, and a shower mix running at 40c at 10L/min and 10 minute shower it will use 50L of hot water. With 4 people thats 200L, so I think i need around a 250L tank.
This also seems to agree with other info i've seen that says to allow 50L per person, then another 50L.
Does this sound about right?
At this point where do I go from here? There seems to be many brands of cylinders around, is there much difference in them? Are there any that are recommended, or should be avoided?
Many thanks
Many thanks
